ported tb, 4500 idle
i just got my ported throttle body and it idles at 4500, the blade doesnt seem to fully close, how would i lower the idle screw? take it in or out?
Did you hook up the vacuum line to the new TB? Is the hole on the TB drilled out to a larger diameter? Is the TB itself over ported around the blade? Have you tried to recenter the blade? My old TB stuck because the blade wasn't centered...Sounds like there is more than 1 thing wrong. That idle is waaaaayyyyyyyy to high.
some of the later model f bodies have an adjustable throttle body. if you follow the cable form the body you should see a box like unit on it. It's not to big but that is where you can adjust it.
