New LS1 Owners - Newbie Tech - Gauges quit working???
cool87gn
01-26-2008, 08:26 AM
This Morning I started my car and my check engine light was on and the fuel, temperature and rpm gauges would not work. I restarted the car twice and they still won't work? What could cause this?:barf:
The Postman
01-26-2008, 11:56 AM
are all of those gauges electronic, pretty sure they are....idk about the temp though...if so it could be a blown fuse..just a thought
cool87gn
01-27-2008, 09:29 AM
The fuse was fine. It has to be something else. Has anybody had this problem?
2fast99Z
01-27-2008, 07:24 PM
maybe a loose connection on the dashboard end of the wiring? if not that or blown fuse (which you already said is fine) idk...unless a wire got cut somwhere, but i don't think thats very likely.
Fast99408
01-30-2008, 03:47 PM
those guages are all connected together you have to replace the cluster caus eyou can not just replace one thing at a time they are all hooked together in a sequence
99blancoSS
01-30-2008, 04:51 PM
My Op guage tweeked, I[m in the same boat. Dont want to swap the whole cluster,thinking about going mechanical or maybe dyno tune offers an led?
jt7282
04-24-2008, 06:10 PM
my gauges just took a shit, the exact same way, what did you find out. pls let me know:bang::bang:
99bluefirebird
04-24-2008, 06:25 PM
mine quit like that and I took the panel off, cleaned off the ground and the connections, and it worked again. Other than that, you just have to start testing wires from the ECM. Probably ground related though if they all quit at once and the fuse is fine.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
