Cam Retainer Plate
Old 01-26-2008, 12:17 PM
sh33p4u's Avatar
Default Cam Retainer Plate
Hey guys -
We are doing a cam swap on my friends '99 TA. On the cam retainer plate, the very top bolt's threads wore out I suppose. When we pulled the bolt out it brought some of the threads with it, so when we tried to put it back in and torque it down, it just kept spinning.
We tried to rethread the whole, but this didn't work. My question is, is it ok to run with 3 bolts? Or do you absolutely need 4 bolts on the cam retainer plate. And if you need 4 bolts, anyone have any suggestions on how to fix the threads?
Thanks,
Andy
Old 01-26-2008, 12:27 PM
Fratsit's Avatar
I would run it as designed. 4 bolts.
You may be able to Helicoil it.
R/
Frat
Old 01-26-2008, 12:43 PM
vettenuts's Avatar
Heli-coil the hole. If its not blind, you need to ensure you don't dump chips into the motor. On the upper bolt, it may go into the valley so if it is not a blind hole you may want to pull the valley cover so you can recover the chips.
