How to mount a LS1 to a engine stand?
Old 07-08-2003, 02:41 PM
8 Sec Tuner
Mike TexaSS's Avatar
Default How to mount a LS1 to a engine stand?
I just bought a AC Delco engine stand from orielys last night. Im going to pick up my motor today what bolt should i use to secure the engine to stand? Grade 8 what sizes? What length?
Old 07-08-2003, 03:11 PM
C4VetteLS1's Avatar
Default Re: How to mount a LS1 to a engine stand?
umm almost any bolts will work.
Grade 8 bolts dont have a higher shear strength so they arent really neccesary... grade 5 or any normal bolt will be fine.
Old 07-08-2003, 03:31 PM
8 Sec Tuner
My real question is what size bolts do i need 1/2 inch 3/8ths ect..
Old 07-08-2003, 03:38 PM
NO CATZZ's Avatar
They are metric...I believe they are 12mm shank size. Just bring one of your bellhousing bolts into a hardware store/auto parts store and get some with the right thread size but long enough to reach through the engine stand. You should pick up some washers also...for both sides...the engine stand will leave small gouges on aluminum blocks.
Josh
Old 07-08-2003, 11:54 PM
Moderator
John B's Avatar
The bolts are 10mm x 1.5 pitch thread. I suggest getting a hardness of at least 9.8
Quick Reply: How to mount a LS1 to a engine stand?
