Is my stock shifter a Hurst?
Old 01-26-2008, 05:20 PM
Spiers's Avatar
Default Is my stock shifter a Hurst?
I have a 1996 WS6 all stock, is my stock shifter a Hurst or non-Hurst??
Old 01-26-2008, 09:42 PM
LSX Mechanic
Damian's Avatar
Post a picture of it
Old 01-26-2008, 10:14 PM
The Manalishi's Avatar
If the stick says Hurst maybe. If not No. You'd have to post pics or check the RPO code that I don't remember off the top of my head but a quick search will find it for you.
Old 01-27-2008, 02:11 AM
DBEST369's Avatar
I have an H on mine so mine is
Old 01-27-2008, 09:26 AM
sdm1234's Avatar
i didn't think LT1 cars had a hurst package, did they?
Old 01-27-2008, 10:01 AM
Switchblade's Avatar
I believe the hurst shifter was available on all LS1 cars only - optional on the 98's-99's, then became standard equipment on 00's-02's.
Old 01-27-2008, 11:13 AM
Spiers's Avatar
Here's some pics....I don't see an H on it anywhere? I was hoping to get the WS6 Store short stick, but they say if you have a non-Hurst then it will hit the center console...
Attached Thumbnails Is my stock shifter a Hurst?-picture-001.jpg   Is my stock shifter a Hurst?-picture-005.jpg   Is my stock shifter a Hurst?-picture-006.jpg   Is my stock shifter a Hurst?-picture-008.jpg   Is my stock shifter a Hurst?-picture-009.jpg
Old 01-28-2008, 09:05 AM
BigKap94z's Avatar
My 2000 did not come with the factory hurst, and niether did my friends 02 Z-28.
Old 01-28-2008, 09:48 AM
jmm98LS1's Avatar
The shifter pictured is most likely not a hurst. Yours didn't come from the factory with one, so it would have to be added later for you to have one. Odds are if that happened, they wouldn't have kept the stock stick & ****.......but it's possible I guess. Need to look at the shifter base to be certain.
Old 01-28-2008, 11:16 AM
Moonder's Avatar
No, its not.
Old 01-28-2008, 12:27 PM
zman1969's Avatar
Default shifter
you'll have to remove the lower boot to tell , OE and Hurst shifters used stock handles, so no way to tell w/o removing boot.
Old 01-28-2008, 03:14 PM
Z284U2TRY's Avatar
Hoe does everone know that it is not a hurst? The only way to tell is to look at the base.
Old 01-28-2008, 06:25 PM
Spiers's Avatar
I didn't know it would be on the base, I'll get the boot off to look at it soon as I get a chance. BUT, if it didn't come from the factory with one, then I know it's not....my car's 100% stock. That's what I was asking, if mine came from the factory with one...
Old 02-09-2008, 03:36 PM
Wally Wimple's Avatar
An OEM Hurst Shifter will come with a Leather **** with an H on it.
Old 02-09-2008, 04:27 PM
RPO Code is: BBS - **** SHIFTER HURST
