General LSX Automobile Discussion Non-technical LSX related topics.
Big problems......well sorta front turn signals dont work.
Old 01-26-2008, 06:17 PM
onebadazzls1ta's Avatar
Default Big problems......well sorta front turn signals dont work.
After replacing both only the running lights work, the turn signals in the back work fine as well as the hazards, multi function switch gone bad? How hard are they to fix? What else could it be?
Old 01-26-2008, 06:24 PM
venomhp's Avatar
check all the fuses?
Old 01-26-2008, 06:29 PM
not yet the parking lights work and like i said the rear turn signals work both sides
Old 01-26-2008, 06:51 PM
DropTopBird's Avatar
It sounds like one of the filaments has blown in each of the bulbs up front. Have you tried changing them? If its not them, or you get the turn signals to work for a minute, it could be the harness. My left harness for the DRL burnt out.
Old 01-27-2008, 05:30 PM
yeah I tried changing them both filiments where good the driver side one keeps on shutting off and on it's loose the damn thing looks burnt to a crisp, the turn signal on the passenger side is ok they both work turn ddl and running light. They are listing a completely different socket for our cars according to advance auto parts, Whom I work for. It's calling for a 1157 round socket not a 3057 blade style. It appears that the previous owner has already replaced the passenger side turn socket . Anyway anyone know where I can find the right style turn signal socket?
Old 01-27-2008, 05:35 PM
Phoenix 5.7's Avatar
blade style is correct, and i think it might be 3157 bulbs.
also check ur rear lights, the whole side won't blink if either a front or back bulb is burnt
