Intake manifolds
Intake manifolds
In your opinions put these intake manifolds in order best flowing on top ans worst flowing on bottom. I just want to see opinion
regular ls1
ls2
P/P Ls1
Ls6
BBK intake manifold
fast
regular ls1
ls2
P/P Ls1
Ls6
BBK intake manifold
fast
most people only have experience with 2, maybe 3 intakes at the most. most of us would be basing our opinion on what we've read. also, most people would put the FAST above all the others.. the only real debate IMO seems to be BBK or LS6.
Restricted User
I agree, BBK is debatable along with the weiand because of heatsoak issues. P/Ping an LS1 intake would be a complete waste of time and energy; and an LS6 is your best bang for the buck mod.
Thanks for the links. I have been searching & haven't found a link comparing the LS6 to the LS2. There isn't one in the stickies. Maybe the moderators can add these links. Granted, different set-ups & tuning may yield different results. However, I've seen enough to axe my LS2 intake. We were going to run a comparison against my Weiand in the Spring, but, I see no need to do so now.
Let's see the numbers. My LS2 is ported & internally filled & smoothed for maximum efficiency. However, I haven't seen evidence to prove that it out flows even an LS6. Further, I have seen dyno sheets that actually show a loss in torque & power early on in the run (low RPM). I would be very interested in your data. Please post more information. Thanks
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
This is a what I based my decision on to send my ls6 intake off to tpis to make it a 90mm with a 90 tb.
NOW If I had a ls1 intake I would spend the money on the fast because in the end if you buy a ls6 intake for 400 or so and send it off in the ends its the same caust as a FAST.
Another thing is if you plan on using nitrous and how much if you plan on alot get a strong intake thats not going to blow up the Fasts have been know to do that even though they are alot stonger than the ls6, But somthing made of Aluminum would be a good choice if you were planing on alot of nitrous.
Retired Street Racer
