y-pipe to cat bolts part #
Old 01-27-2008, 02:50 PM
b0pric01's Avatar
Default y-pipe to cat bolts part #
I need some bolts for the stock y-pipe to cat flange. They are the bolts that thread into the flange on the cat and have a nut that holds the flange on the y-pipe tight. I got some replacements from autozone but the entire bolt isn't threaded and it doesnt give enough clamping force to hold the flanges together. could somebody PLEASE help me out? I tried search already for those of you that are going to say that.
Old 01-27-2008, 03:09 PM
snake hunter's Avatar
I have some of them, but why not just go to a hardware store and get some all-thread? Or you could get some bolts long enough and just torque 'em down....You have a lot of options here. No need to worry about oem parts here......
Old 01-27-2008, 03:36 PM
b0pric01's Avatar
i tried that, had problems and they broke. It would just be easier if I could get the same ones that I know will work. trust me ive already been there and had something that should have taken 1/2 hour at the most take me 3 hours because of broken/stripped bolts even with threads matching up.
