FS 94 Black Formula
FS 94 Black Formula
EDIT: More pics and info added. scroll down.
First off Ill say the car is NOT running. It died on me Dec. 31 and I havent had much time to mess with it. Its at my parents house located in between Weatherford and Granbury. I stopped for gas then the car wouldnt start back up on me, might be the opti, might be fuel pump im not really sure. The car is basically stock except for a KN CAI and Flowmaster. Also has no AC. The compressor was removed and a blank pulley was installed. Odometer is just under 150k. A4. Everything else worked when I last drove it. Body is still in pretty good condition. Has a few small paint chips and a dent in the hood from previous owner, but its not too noticeable. Heres the only pics i have.
Both window motors work however the passenger side is slow.
Both headlights raise and lower with no grinding noises.
The power side mirror control works.
All lights and gauges work.
The speedo is off around 5-10 depending on how fast you are going.
Front rotors are low.
Items replaced by me since ive had it, brake pads, wires, plugs. The previous owner said he replaced the water pump and opti.
Never had any transmission problems since ive owned it. Oil pan may need a new gasket cause its oily under there, but not bad. I check all fluids regularly.
Would make a good track/project car.
Asking $2000
Asking $2000
why take a perfectly good car (from what you described) and make it into a drag car? Id find a roller for that. Whoever gets this, fix it and take care of it. If I get it, thats exactly what ill do.
More pics
dent in the hood
dash crack
another one
console cracked
paint chip on driver side
*on passenger side under blinker
passenger side chipping at bottom
that damn thing broke but everything works and you can still use your blinkers
also, rear tires have pretty good tread while 2 fronts are pretty much gone. there is a stain in the passenger seat, the camera wouldnt pick it up because its the same color as the material, it just made the fabric hard and a lil darker (like it would look if it was wet).
**Also forgot to mention mike came and looked at it last night, and he ad the little tool to pop the fuel line off, and we tested the pump and it works, so Im guessing its the opti spark. Big thanx to him for that.
dent in the hood
dash crack
another one
console cracked
