94 Pontiac Firebird with Possible Blown Head Gasket?
Old 01-27-2008, 10:20 PM
bbchaos's Avatar
Default 94 Pontiac Firebird with Possible Blown Head Gasket?
Hey all, new to the forum.
I just bought a 94 Pontiac Firebird for 1 grand, knowing it had engine troubles, but I was hoping to fix it up. It is a 5.7L V8 engine. It starts right up, and idle seems fine. But when I push on the gas, the acceleration is horrible. At one point I was at a red light, I rev up to around 6k rpms, it barely moves, and I see white smoke coming out of the exhaust. It does get going, it is just really slow. I am thinking it has a blown head gasket, but I haven't had a chance to check the oil yet. Are there any other things that could be wrong?
EDIT: other details are 06 inspection sticker, tires seem worn. seller reported initially that it ran and drove great, am i missing something?
bbchaos is offline
Old 01-28-2008, 09:18 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Worn out spark plugs? If it was a blown head gasket, you should be able to smell oil burning .
The smoke could just be from worn valve seals.
y2k_ta is offline
Old 01-28-2008, 03:09 PM
bbchaos's Avatar
forgot to add that part, i actually did smell oil burning, guess that must be it then? ill be able to actually check the oil soon
bbchaos is offline
Old 02-06-2008, 11:19 AM
3.8SFITURBO's Avatar
Do a compression test
3.8SFITURBO is offline
Old 02-06-2008, 12:02 PM
BadGTho's Avatar
you mean coolant
alot of oil burning is typically rings in the LT1s
BadGTho is offline
Old 02-06-2008, 01:31 PM
'Bird Director
y2k_ta's Avatar
Originally Posted by BadGTho
you mean coolant
No, I meant oil.
y2k_ta is offline
Old 02-06-2008, 01:37 PM
BadGTho's Avatar
No, I meant oil.
hmm ok.
ever had a blown headgasket>?
BadGTho is offline
Old 02-08-2008, 07:57 AM
'Bird Director
y2k_ta's Avatar
hmm ok.
Umm, yeah I've had a blown head gasket before....
y2k_ta is offline
Quick Reply: 94 Pontiac Firebird with Possible Blown Head Gasket?
