what do y'all think my car will run N/A and on the nitrous...
Just saw another thread like this. and im a bit curious. The car was a prev auto so im assuming it has 323 gears, but the car is a 6spd. here's a copy/pasted list of the mods.
Let me know what you think i'd hit. Im not planning on running it, so im just curious.
thanks
RPM stage 3 LS6 Heads
2.02/1.60 valves, been ported on both intake and exhaust side, milled .030
Crane dual springs good to .650 lift
RPM 4 .595/.601 232/236 114lsa.
100 shot NOS dry shot/ purge etc.
A-pillar pod with autometer ultralite fuel pressure/nitrous pressure/ a/f ratio
Raptor shift light
Hooker LTs, 3in. TD with ORX, bullet mufflers dumped at the
BMR Sway bars, LCAs, relocation brackets, sub frames, etc
Hotchkis PHB
Eibach sportlines
LS6 intake
SLP lid and bellows, NGK plugs, SVO Green Top 42lb injectors, LS1 EDIT done by RPM
LS7 clutch/pressure plate/LS2 flywheel
thanks
Raptor shift light
Hotchkis PHB
Eibach sportlines
LS6 intake
I'll drive it for ya if you're scared
Off the spray I'd say mid-upper 12's and spraying, I'm guessing high 11's to low low 12's. if you had a good driver behind the wheel (yourself or someone else)
it would run 11's on motor if it were still stalled, but the 6 speed is gonna be a bit tricky to launch with street tires. so like a 12.2@117 would be my guess on motor. you would need a set of drag radials and a set of brass ***** to launch it on a stock rear end and ls7 clutch.
LOL was that the day you were behind me? I wasnt anywhere close to getting on it. I might give it a little gas here and there in 2nd gear, but nothing major at all. everyone that knows me knows I baby my cars.
Don't try and run it Patrick. I been watching video's on the M6/10 bolt f-bodies breaking the rear ends like crazy, haha. Now I'm kinda worried about breaking mine! The way I see it is if I break the rear end, it's just a damn good excuse to throw a 12 bolt underneath it!
