Was going for a drive today and check engine light came on
Old 07-08-2003, 09:53 PM
RJF
RJF's Avatar
Default Was going for a drive today and check engine light came on
I just got the car off the stands today It had ran for 2 hours today while on stands not constanlly though i little here and there checking wires and stuff.Well I had no lite so I took it out for a test drive and the check engine light came on.Anyway to re-set the computer
Old 07-09-2003, 12:15 AM
RJF
RJF's Avatar
Default Re: Was going for a drive today and check engine light came on
ttt anyone
Old 07-09-2003, 07:56 AM
malibu350's Avatar
what you want to know how to reset trouble codes? I believe that you have to pull the fuse for the computer....or are you looking for something else?
Old 07-09-2003, 02:43 PM
pvhideout's Avatar
Unhook your bat. for 15 mins. That will reset your computer. But you should scan it to see what the code is.
Old 07-09-2003, 06:04 PM
RJF
RJF's Avatar
will i have to reprogram my gear change and shift points and rev limiter?????
Old 07-09-2003, 06:07 PM
RJF
RJF's Avatar
could it be that the battery is bad im running gauges,underbodies,a big amp and strobes?could that be it?
Old 07-09-2003, 06:17 PM
RJF
RJF's Avatar
i dont have anything to scan it with
Old 07-09-2003, 06:20 PM
jaywoo's Avatar
You could go to Autozone or Advance Auto and have them pull the code for you. Just resetting it probably isn't the best move. Would be helpful to know what set it in the first place.
