Timing Chains
Old 07-08-2003, 10:19 PM
1BADAIR's Avatar
Default Timing Chains
I am getting ready to install a TR224. The local shops told me to use the stock timing chain or a new stock one.
I would like a good single chain. Which should I get(JWIS,Single Rollmaster,) and where can I get it. It has 20,000 miles and the oil pump was replaced about 9000 miles ago.
Old 07-08-2003, 10:22 PM
horist's Avatar
Default Re: Timing Chains
I'd reccommend a Rollermaster.. give SDPC --> a call about them
Old 07-08-2003, 10:30 PM
DEEZ98Z's Avatar
I am going to go the other way... JWIS. When I talked to Thunder they told me this is the chain that they use so I went with it Although I think that the Rollermaster is cheaper.
Old 07-08-2003, 10:47 PM
WicketMike's Avatar
I am going with the Katech one that comes in the C5R's
Old 07-08-2003, 11:08 PM
Zero2Sixty's Avatar
I just received the RollMaster Double chain from SDPC ($74.00 to my door), this is a high quality piece.
Old 07-08-2003, 11:43 PM
Cal
Cal's Avatar
Yeah, same here . . . I just took the stock chain out and put the JWIS in, and I noticed the links were made out of thicker metal than the stock chain was.
Old 07-09-2003, 06:41 AM
Buckshot's Avatar
A buddy and I installed Rollmaster dual rollers in with our h/c. Nice piece of work.
Old 07-09-2003, 07:42 AM
Tin Indian's Avatar
Actually, Rollmaster does not make chain. If you purchase a Rollmaster timing set (single or double), you will get the timing gears made by Romac/Rollmaster, and the chain made by Iwis Ketten
Old 07-09-2003, 07:46 AM
Ebbsnflows's Avatar
I went w/ the JWIS from Katech to replace my 70K mile stocker. I didn't feel like messing w/ the whole Double roller swap out (and feel that it is overkill IMO).
BTW...isn't the rollmaster chain made by JWIS?
Old 07-09-2003, 07:57 AM
Tin Indian's Avatar
JWIS is actually Iwis Ketten
http://www.iwis.com/en/main/index.php
Old 07-09-2003, 02:55 PM
Constrictor 98TA's Avatar
Rollmaster doesnt actually make chains, they make the gears. Any chain you buy from Rollmaster *IS* an Iwis (not Jwis) chain.
For proof, check out a closeup of my Rollmaster Double Roller chain I got from SDPC.
http://www.metalreviewcentre.com/images/Jwis.jpg
Old 07-10-2003, 07:05 PM
JRcamaroZ28's Avatar
looking at the picture you can see the treads from the cam bolts. is this the way it's supposed to be? I put my cam and rollmaster together and they have the same gap behind the gear and the face of the cam. I would have thought you would want the face of the cam to be all the way into the back of the cam gear
JR
Old 07-11-2003, 06:48 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
I'd go with the 2xRollmaster it's a quailty piece. One less thing to worry about later on.
