Nitrous Oxide - Teflon Sealant??
Bill Bowling
01-28-2008, 10:53 AM
Started puting together my fuel gage sender and they say use Teflon sealant, not teflon tape. I went to a number of places and no one has anything called teflon sealant. I have some thread sealant. Is that the same?
Thanks,
Bill
:engarde::chug:
2002t/a06
01-28-2008, 10:57 AM
i think it will work fine??
MetallicaMatt
01-28-2008, 11:02 AM
Napa or Advanced should carry it. Its Teflon paste.
Tape will work fine, just be VERY careful not to get near the end of the threads b/c you could get some tape in the line...clog a selenoid, etc etc bad things etc etc
Bill Bowling
01-28-2008, 11:05 AM
Advanced did not have it. I might try Napa. That is about the only one I did not try- it farther away.
Thanks,
Bill
jmill96Z
01-28-2008, 11:12 AM
Any hardware store will carry the paste. Just look in the plumbing section.
MetallicaMatt
01-28-2008, 11:26 AM
Plumbing/glue/sealants etc
Mike@HSW
01-28-2008, 11:31 AM
I would think just about any hardware store will have teflon paste, do not use teflon tape, you dont want that getting pulled into your line.
mrdragster1970
01-28-2008, 02:07 PM
I use the teflon plumbing paste also.
jmill96Z
01-28-2008, 02:31 PM
I still use the tape. It works great as long as you install it correctly
myfast70
01-28-2008, 03:43 PM
Or you can just use Red Loc-Tite. That's what came with some of my NX stuff and I used it on all of my pipe fittings and have not had any issues. It can also be removed if need be. No chance of the teflon paste drying up and clogging a nozzle or jet.
Bill Bowling
01-28-2008, 04:06 PM
I just checked and I have a new Red Loc-Tite stick. I think I will give it a try.
Thanks,
Bill
:chug:
myfast70
01-28-2008, 04:23 PM
Thanks,
Bill
:chug:
A little dab will go a long way! :D Don't go crazy with it.
bigsticksupra
01-28-2008, 10:56 PM
Permatex makes the liquid teflon thread sealant. you can get it at pepboys and kragens.
Nitro Dave's Nitrous Outlet
01-28-2008, 11:02 PM
Like suggested above. A hardware store is the best place to go. It will be in the plumbing section.
Ace Hardware
Home Depot
Lowes
tamikews6
03-15-2008, 12:03 PM
If you don't want to go to the store order it here.
http://www.amazon.com/s/ref=sr_nr_i_1?ie=UTF8&rs=&keywords=teflon%20%20paste&rh=i%3Aaps%2Ck%3Ateflon%20%20paste%2Ci%3Atools
Bill Bowling
03-15-2008, 12:39 PM
I got some at Home Depot.
Thanks,
Bill
:chug:
Robert56
03-15-2008, 01:40 PM
Thanks,
Bill
:chug:
Be careful using the red lock tights. it's designed for stud locking and not really meant as a removable type sealant. A better option is to use Blue lock tight as it's meant as a sealant that can easily be disassembled. the red can cause problems, esp with alum and yes I use both on a daily basis, in many applications, in the Maritime industry. my favorite for home use is Blue 430 IIRC, as it's designed to still seal properly even when contaminated with oil, most wont work well if not totally clean. Actually, any soft seal that's used on pipe fittings will do. Teflon paste comes in many brands and names, and at work we use Seals Pipe.
Robert
