Mustang vs. Dynojet
Old 07-09-2003, 01:09 AM
Onyx Z's Avatar
Default Mustang vs. Dynojet
What are the differences and why do they dyno differently?
Ryan
Old 07-10-2003, 05:44 PM
WILWAXU's Avatar
Default Re: Mustang vs. Dynojet
ttt
Old 07-10-2003, 09:10 PM
BurnOut's Avatar
I read an article lately, and IIRC, the gist of it was that the Mustang dyno has a provisionable parameter to take into account rolling/aerodynamic drag. That is to say that the Mustang drags the brakes on the rollers according to what the variable is set to. I think.
Anyhoo, the article had a car dyno'd on a DynoJet, a Mustang, and they had an optical 5th wheel as well... they found that actual 50-70 times (as measured by the 5th wheel) were MUCH closer on the Mustang dyno than on the DynoJet. Additionally, IIRC, a DynoJet simulates something like a 2450 pound load (the weight of the drum??); so if your car weighed 2450 pounds, your acceleration times while rolling would be approximately the same as on a DynoJet or a Mustang dyno. I think.
Old 07-16-2003, 01:19 PM
Ed Blown Vert's Avatar
But if you gain say 10% on a Mustang dyno, would it be 10% on a DynoJet??
Old 07-16-2003, 01:37 PM
v8maro's Avatar
not if the drag on the mustang is dynamic or exponential.
Or
the gain on the car is exponential and not linear
-Steve
Old 07-16-2003, 01:59 PM
Crazyquik's Avatar
Mustang is better for tuning as the load is programable depending on the type of car.
So you could dyno a 4000 lbs truck and then a 2200 lbs car, and get a better tune as the dyno could be optimized for each.
J.
Old 07-17-2003, 03:32 AM
smokin' joe 00 ss's Avatar
On the same car you can see as much as a 30 to 50 rwhp difference from the mustang dyno to a dynojet. The Mustang dyno will give you real world #'s.
Old 07-17-2003, 09:19 PM
promod1955's Avatar
a mustang dyno is an eddy current dyno. a dynojet is an inertia dyno. most eddy currents dyno lower. besides mustangs are always down on power...
Old 07-18-2003, 09:52 AM
lol,
Old 07-18-2003, 12:42 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
My numbers are mustang figures.
Old 07-18-2003, 03:17 PM
Where did you get that dynoed at, those are the best C1 cam and no head LS1 #'s with 4.10 gears and a 12 bolt on a Mustang dyno on the face of the planet. Most stage 2 heads & cam cars on a Mustang dyno come in between 360 & 390 rwhp. Congrats on the great #'s what kind of 1/4 mile times do you turn?
Old 07-18-2003, 05:36 PM
critter's Avatar
Pardon my ignorance. I know about eddy current and water brake dynos, but what is an inertia dyno? I sounds like the resistance to the power (or more properly torque) is the inertia of a large drum rather than an electrical or water brake.
Old 07-18-2003, 07:03 PM
Argon Z's Avatar
i researched it and i found that it was somthing like 11 percent less then a dynojet.
Check my sig. Mustang dyno numbers, yet i am pulling alot of mph in the quarter.
A general rule
e.t. is a function of traction
mph is a function of hp
Old 07-18-2003, 09:00 PM
!LS1 11 Second Club
I wish I had a 12 bolt! 1/4 mile times suck major, major *** (I've only run 2 passes w/ this setup), as I spin the stock Goodyears F1's 'till deep into 3rd gear! That said, my only traction gear is 4th. Even then I trap @ 111. Er, eh, cough cough, 13.0 w/ 2.2 Nittos anyone?
Ain't got no traction baby!!!
