GTO Clutch vs F-Body Clutch. Whats the diff??
I know that the m12s and m6s are the same so why the different part number for the clutch and pressure plate? Do they use a different slave and/or TO bearing maybe? The reason I ask is I picked up a SPEC setup from an 05 GTO to go in my Fbody. Now the spec flywheel part numbers are the same for both cars, only the pressure plate is different so the LS2 flywheel doesnt factor in (in my case anyway). Anyone know if I can just bolt it in or ????
