Shim on flywheel spec 3 +
Should we shim the flywheel on spec 3+, I am still thinking of changing not impressed by spec. We will see after their warranty. 2500 miles under 500 hp rear wheel. no slicks. proper break in even a little extra it was raining.
JS, I am curious as to your dissatifaction above if the clutch wasn't in the car yet. What flywheel are you using? Did you install the shim behind the slave cylinder? Let me know and I will be happy to assist you. Thanks!
