LQ4 oil pressure sender, LS1 F-Body harness
Old 01-29-2008, 09:11 AM
itslow's Avatar
Default LQ4 oil pressure sender, LS1 F-Body harness
The LQ4 uses the short style oil pressure sender with the small three contact plug. The '99 F-Body LS1 harness I am re-working has a plug for the tall style LS1 sender with the larger bodied connector. Do these two senders function the same, allowing me to simply change the harness connector to the smaller style? Which wires on the harness correspond with which pins on the LQ4 sender?
