WTB - Track car in street trim - road race/autox
I am looking for a capable part time track car retaining street driveability. I am not looking to compete, just play in some open club events at a local track (www.harrishillroad.com) here in central texas.
Basically, I am more interested in a durable car with finished suspension/brake/chassis mods. The more complete and extensive modded, the better. It needs to handle flat, corner hard, and stand up to some abuse.
I am most interested in a M6 foremost. I prefer LS1 but the right LT1 will do.
I am not looking for a $15K+ dedicated stripped out road racer.
Minor cosmetic issues are ok, as are minor mechanical issues. If the trans, rear or engine is shot, it needs to be cheap for my interest to peak. But if the CAR fits the bill, and these are out of service, that is ok as long as the price is reasonable and the car is close.
I am not at the moment looking for a stock M6 F-body unless the price is right: i.e. high miles, low price, etc. (i.e. room in my budget to add on suspension and brakes and keep the total cost down).
Keep it under 10K and let me know.
Email is the BEST way to contact me: ruf455@msn.com
I have a lsx swapped 2nd gen (90) rx7 with 6 speed that would work wonderfully for what it sounds like you're after. I built it for the same reasons and now have a hankering for something I can take the kids out in and still have fun. My not be what you're after and it may be a bit higher than you want to go.... but it needs very little to be ready for the road course as it has a cage, coilovers, brakes, bushings, sticky tires on wide wheels etc. It is not stripped at all and is very much a street car. See this thread if you're curious.
https://ls1tech.com/forums/vehicles-sale-lsx-powered-only/853643-ls1-powered-90-rx7-fs-ft.html
I know we're kind of far and it's not for eveyone. Good luck either way!
Hello,
First off the only reason I am selling this car is I have a son due on the 12th of Feb. And instead of a 2 seater coupe lsx car, I need a 4 seater Lsx car (GTO) wich I will be buying after this is sold.
I would be willing to trade for only a GTO, and maybe a lsx Truck.
The car is a: (Never Wreced)
2001 M6 Red Camaro SS
Brand New Lq9 with only 700 miles since rebuilt.
60,000 miles on the frame
Ebony interior
Engine
Tsp Edelbrock Terminator Heads with dual springs
ARP Head Bolts
T-Rex cam
Hardend Pushrods
Fast 90mm Intake
Fast 90mm TB
42lbs SVO injectors
Professoinal Product Fuel Rails
ARP Rod Bolts
Bulldawg Double Roller Timing Chain
SLP underdrive
SlP Lid
K&N filter
Cold air intake mod
Engine coolant bypass mod
Walbro 255 fuel pump
It is sd tuned, but I have a 80mm maf if you rather have that.
Supension
Pro 5.0 Shifter
Textrilla clutch
Spec Billet Flywheel + Arp Flywheel bolts
Both balanced together
4:10 Gear
Bmr adjustable tq arm
adjustable lca's
adjustable Panhard bar
Drilled slotted rotors
Painted red calipers with ss deacal
18" Boyd Blaster wheels. Highly polished
265/40/18 and 295/35/18
Exhaust
Hooker Coated 1 3/4 headers
Tsp y with a custom Flowmaster Merge collector
Slp loudmouth exhaust
Flow master Muffler
Two Cutouts
Interiour
Aem WIdeband
Corvette Dash overlays
Trans Am Bezel
Electric In car Fuel pressure gauge (dual MOunt pillar) Multicolor display.
Hurst shifter
Slp Floor mats
Leather scale 1-10 it is a 9.5 easy. I will post pics
Never had dynoed , but this thing is nice, I have no doubt that if you ride in it you will be satisfied. Never been sprayed and only went to the track once, but could not get a good enough pass to get a good time. (wheel hopping)
I do have other stuff like draglites and tires and Nitrous if wanted not included. I can also take some of the stuff off if you want it removed to lower the price.
I will post pics as time go on.
Asking 18k or best offer.
Thanks
Ebony interior
Engine
ARP Head Bolts
T-Rex cam
Hardend Pushrods
Fast 90mm Intake
Fast 90mm TB
42lbs SVO injectors
ARP Rod Bolts
SLP underdrive
SlP Lid
K&N filter
Cold air intake mod
Supension
Pro 5.0 Shifter
Textrilla clutch
4:10 Gear
adjustable lca's
Exhaust
Flow master Muffler
Two Cutouts
Interiour
Aem WIdeband
Trans Am Bezel
Hurst shifter
Slp Floor mats
Thanks
