90 Mustang LX with LS1 carburetor...need help
Old 01-29-2008, 03:07 PM
F-Body Lover's Avatar
Default 90 Mustang LX with LS1 carburetor...need help
Me and my friends finished this project today,it has LS1 with ported heads,23×/23× 110LSA cam(×=cant remember the last number),victor jr intake swap with 750cfm holley carb,TH-350 with shift kit,4500 stall and 3.73 but we got a problem that the car cut offs at 4000 and we dont know which curve chip to use (we lost the paper that comes with the MSD 6SL module) we put curve 2 and the car cut offs at 4000 we putted curve 1 and it cut offs really hard around 3800 so which curve chip we use? I will post pictures later
Old 01-29-2008, 03:52 PM
some pictures
Old 01-29-2008, 06:56 PM
SMAX's Avatar
http://msdignition.com/ignition_33_6010.htm
i dont think you should be running into that problem, but nice lookin setup though.
Old 01-29-2008, 06:59 PM
LS_STANG's Avatar
Did you run the aje k-member?
Old 01-29-2008, 07:25 PM
LS stang yup the AJE k member for 4.6 ford and LS1 chevy
Smax thnx alot man
I will post more pictures as soon as I can
Old 01-29-2008, 07:33 PM
btw smax I think we need to tune the module right? we didnt do that we just finished the project put curve 2 chip start the car take it for a lil ride give it a lil gas the car cut offs at 4000 RPM,from the instructions of the PRO DATA+ do I need to run this software first? or its ok if not?
Old 01-29-2008, 09:13 PM
spatton100's Avatar
The MSD 6010 I have was preset with a 5500 RPM limit and I had to hook up the laptop and change it to a higher number.
Old 01-29-2008, 09:15 PM
oh ok thnx everybody
Old 01-31-2008, 07:15 AM
LS_STANG's Avatar
Thanks I guess I will be ordering mine this week
Old 01-31-2008, 11:06 AM
Top Secret's Avatar
Why in Gods name did you put a 4500 stall converter in that thing?
Old 01-31-2008, 11:13 AM
we told the owner he dont need 4500stall a 3500 is good enough for his cam but he refused and bought this 4500stall for cheap the car is too heavy in the start
btw Im not the owner im just the builder with the owner and couple of friends
Old 01-31-2008, 01:47 PM
Darracq's Avatar
That thing will scream with a 4500 converter, i have a 3600 on a stock engine and wished for more.
Old 01-31-2008, 03:11 PM
Ravenous T\A's Avatar
sounds like it needs a 4K stall with that cam and gears.....4500 seems like its overkill?
Old 01-31-2008, 03:17 PM
the cam opens from 3200 and close 7000 like the owner is claiming I dont know the rest of the cam specs but I think he needs 3500 stall I dont know
Old 02-03-2008, 01:24 AM
DCx
DCx's Avatar
i just got my carb setup running and i dont have any issues with it cutting out. i think i bounced it off the rev limiter today. i have it set at 6500. if you need the install instructions you can easuly find them on line but since i have the image scanned on my computer ill post it up.
i used pill #1 so far just to get it started and it works great. im running a MS3 cam, 750 mighty demon, and texas speed ported heads.
Old 02-03-2008, 03:14 AM
thnx man,we programmed the rev limiter and DAAAAMN that car fly lool we didnt finished the break in and we already flooring it but we are facing a small problem that we will fix soon I hope the C5s and C6s in our country are armed to this LStang
Old 02-03-2008, 03:20 AM
DCx
DCx's Avatar
all that is keeping my 69 camaro swap from tearing up the streets is a new drive shaft! damn i wanna feel the LS power
Quick Reply: 90 Mustang LX with LS1 carburetor...need help
