Pontiac GTO 2004-2006 The Modern Goat
285/35/18 Hmmmmm....?
Old 01-29-2008, 08:40 PM
PapaSmurf2005's Avatar
Default 285/35/18 Hmmmmm....?
Ok, I'm doing new wheels and tires... not by choice.
I had TSW Thruxtons 18x9.5 in the rears, with a 45mm offset. I fit 275/35/18 BFG DR's and KDW2's on them with no issues. I then last put on 285/35/18 Nitto 555RII's with no issues. The BFG's ran 10.9" wide and the Nittos ran 11.2" wide (from each of their website specs).
Now my suspension is not stock. I do have Pedders 5/16" raise drag springs, x-member bushings, etc. I also have BMR Drag Bags but they are only used for the track and I grinded the fender lip off.
I'm going with Ruff Racing 278's with a 48mm offset, which will help shove the wheel/tire in 3mm's more. So this time around I wanted to go with Goodyear GS-D3's, but they only come in a 265 or 285. They are 11.4" wide for the 285's. I'm thinking with the extra 3mm's that they should fit without any rubbing issues?
What does everyone think???
Old 01-30-2008, 12:53 AM
Drew04GTO's Avatar
Was reading this at work, so I didn't get a chance to reply there. 3mm is .118", since they're roughly .2" wider that should gain you a pube hair more clearance than your current setup. Were the tire section widths both on 9.5" wheels?
Quick Reply: 285/35/18 Hmmmmm....?
