Air Pump Check Valve Help
Old 01-30-2008, 12:16 PM
Nick_Rapitis's Avatar
Default Air Pump Check Valve Help
ok so my ses came one and its code p1416 which from what i've found is most likely a clogged up check falve on the passenger side...is that easy to replce on my own? what all is involved? i just got the car not too long ago so im not vary familiar with the engine as its snowy and shitty here so any help would be greatly appreciate! also would it be easier if i just take it to my mechanic to fix? thanks a lot!
Old 01-30-2008, 12:45 PM
2001NBMZ28's Avatar
You can do it yourself. Just unclamp the hose side and pull it off, then use 2 wrenches (one to hold the pipe and one to unscrew it from the metal pipe coming off the header). If it's really on there tight remove the 2 bolts on the pipe and do it off the car.
Old 01-30-2008, 12:50 PM
once i replace it will the codes have to be cleared or will it see that its functioning normally and clear the codes on its own? and where exactly is the check valve...unfortunately i am pretty ignorant when it comes to this stuff so far since im new to camaros...i dont know what it looks like lol if any one has an engine pic and can point it out it would be great thanks!
Old 01-30-2008, 12:51 PM
also, how urgent is it to fix this sort of thing?
Old 01-30-2008, 01:08 PM
2001NBMZ28's Avatar
It's OK to drive with it. P1416 will shut off after a few cold starts without a failure - you can look it up at gearchatter.com for your year and it'll tell you when. The valve is the black disc shaped valve between the metal pipe coming off the header and then connects to the hose - right near the cyl #4 coil pack - can't miss it.
Old 01-30-2008, 02:10 PM
TheSilverOne's Avatar
!AIR = done
Old 01-30-2008, 02:17 PM
ReFtheMC's Avatar
How exactly do you "clean" this thing?
Old 01-30-2008, 03:02 PM
could it be something other than the check valve or will that do the trick?
Old 01-30-2008, 03:42 PM
2001NBMZ28's Avatar
Could be something else, like a collapsed or loose air hose going to the passenger side for instance, but usually the valve is inop/clogged with carbon deposits. It's about $20? at NAPA and only takes a couple minutes to change and would try that first.
Old 01-30-2008, 08:24 PM
yeah i think im going to try that tomorrow...i wish i had a code clearer thingamajigger lol...that way i would know that if it the code came back i need to check something else, now i have to go somewhere to clear the code...then if it comes back i have to go back to see what code it is...oh what a hassle!
Old 01-31-2008, 12:10 AM
JScamaro's Avatar
Do yourself a favor and yank all that stuff out. Then you won't have to worry about the check valves ever again.
Old 01-31-2008, 02:45 PM
ok so i took off the pipe too an i still cant get that little bitch off...any suggestions? i tried some pb blaster and still no go...please help! lol
Old 01-31-2008, 03:21 PM
2001NBMZ28's Avatar
Two large adjustable wrenches for more leverage - friend of mine put one end in a vice to remove his.
Old 01-31-2008, 03:33 PM
yeah thanks i got it now though...hopefully my ses will shut off soon now on its own!
Old 01-31-2008, 09:54 PM
hey will disconnecting the battery work to reset the codes cuz thats what i did for my mustang and it worked but i havent tried it yet on my z28...
Old 01-31-2008, 10:21 PM
https://ls1tech.com/forums/showpost....91&postcount=2
