02Z28
01-31-2008, 10:44 AM
Can I use my Nasty fuel rails and green top injectors off my fast intake, on a L76 intake?
Bring the Noise
01-31-2008, 11:35 PM
Green top's are type 1 injectors are they not.
I think Katech has a O ring kit to allow you to use type 1 injectors in a manifold designed for a type 3 injectors.
The fuel rails will be a guessing game, if they can be used you'll probably need to fab up new brackets.
Katech may have mount brackets and what not to allow you to use LS1/LS6/FAST rails on a L76 manifold.
02Z28
02-01-2008, 11:03 AM
Sounds like I should check with Katech then... Thanks man. :nod:
