bigger valves?
Old 01-31-2008, 11:57 AM
LS1Tech Sponsor
Rob@EFIAlchemy's Avatar
Default bigger valves?
ok i have a set of 853 heads i had ported a few months back is it worth it for me to have bigger valves put in them? i was thinking about going to a 2.02/1.60. i have about 800 bux into the heads with the crane daul springs on them so i really dont want to go out and spend the money on new heads if i can get these closer to them by putting bigger valves in them.
thanx
Old 01-31-2008, 06:27 PM
Apollo0526's Avatar
I'm in the same position you are. What cam do you have, or getting?
Old 01-31-2008, 08:31 PM
bigchuck34's Avatar
i'm in the same predicament. the heads i'm using have 2.00 and 1.60 manley valves but i have a set of 2.02 ferrera's i could use and i need a valve job anyway. should i put in the 2.02's when i do the valve job?
Old 01-31-2008, 08:34 PM
Gunnar@Patriot's Avatar
In many cases you can gain as much flow by getting a good valve job, good bowl work, and using your stock valves. If you decide to go with the larger valves, give us a call we can give some great prices on Ferrea 6000 series valves.
Old 01-31-2008, 08:47 PM
LS1Tech Sponsor
well my current setup on the car is stock ported 853's with a comp 5 angle valve job and a custom cam motion cam 234/240 .627 .641 112lsa. right now the valves clear the pistons but if i go bigger thats going to cut down on my ptv clearence right?but if i pull these heads back off im going to port match them and do a little more work to them and do the bigger valves.
Quick Reply: bigger valves?
