Western Members CA, AZ, NV, UT, CO, NM, HI
Trans Am Owners - Past or Present
Old 01-31-2008, 10:50 PM
blackhawk_02's Avatar
Default Trans Am Owners - Past or Present
Ever have any problems with your head lights?
Like, one go up and not the other? Or a headlight stay up when you turn the switch for them to go off?
Kinda having a weird issue with that. It's rare though, so, I'm confused.
HELP!!!!!!!!!!!!!
Old 01-31-2008, 10:52 PM
bu01's Avatar
did you check the gear, maybe wornout and time to flip it to the unused side of it
Old 01-31-2008, 10:56 PM
gear? hmm... unused side of it? im confused...lol
Old 01-31-2008, 11:02 PM
3.8redbird's Avatar
the gear uses only one side since it only goes up and down a ways and never touches the opposite side of the gear leaving it unscaved
Old 01-31-2008, 11:05 PM
oh... hmm... well, is there an easy way to fix this problem?
Old 01-31-2008, 11:06 PM
bu01's Avatar
the gear that makes them go up and down. that gear, only on side is used
pretend this is the gear "O"
left side-->O<----right side
only one side gets used to operate the lights, since its plastic, it gets worn, but the other side never gets touched. so if you fo in there and flip the gear to the "new" side,then the gear should help the light go up/down like new. that is if the flip has not been done before
they also sell a brass gear to replace the plastic gear, they last longer. i found howto some where for the flip and for the brass, let me see if i can dig it up
Old 01-31-2008, 11:08 PM
bu01's Avatar
edit...
the free flip fix\
http://www.freewebs.com/headlight/headlightmotorfix.htm
Old 01-31-2008, 11:26 PM
awesome, thanks for the help!!!!!!!!!!!!!
maybe ill get around to it this weekend, ill let yall know how it goes...
Old 01-31-2008, 11:30 PM
bu01's Avatar
no prob man. before i got my bird, i read up on a lot of stuff for it. you should have seen me when i was test driving/looking at them, the way the owners would look at me when me and my friends would go through the car with the 'white glove' so to speak. i specially had my friend turn the lights on/off so i could listen to the headlight motor/gears.
then i ended up buying one in texas that i have not seen/heard yet-----LMAO
Old 01-31-2008, 11:43 PM
So*CalWS6's Avatar
NO! NO! NO! Don’t buy the BRASS. I bought the brass gears from Rodney and installed them and a year later my motor burned out and I took it to the dealer and the guy at the dealer said that there’s a reason why they use plastic gears because when the gear gets jammed the plastic will just grind or break and the brass will fight the motor till it burns out. I put the plastic gears back in. I got them from Rock Auto for $10 each which is way cheaper then the brass and a lot cheaper than buying a new motor and it's worked perfect.
Old 01-31-2008, 11:46 PM
cruiSSin LS1's Avatar
nice save there...
So*CalWS6's Avatar
And you don't need anything too expensive since you might be selling your car anyway and look how long your gears hafe lasted so what if you have to change them every 5 or 6 years It's very easy to change trust me you can do it in 20 min.
Old 02-01-2008, 12:07 AM
bu01's Avatar
cool save bro.... stick with the plastics
editing my brass post
Old 02-01-2008, 12:31 AM
fast01z28's Avatar
camaros FTMFW!!!!!
Old 02-01-2008, 12:36 AM
bu01's Avatar
firebird= bird of pray
catfish= tuna
Old 02-01-2008, 12:38 AM
So*CalWS6's Avatar
Originally Posted by fast01z28
camaros FTMFW!!!!!
Your such an ***
Old 02-01-2008, 05:58 AM
lol.... so plastic i go!
Old 02-01-2008, 11:10 AM
01black's Avatar
im having that same problem right now...ive adjusted the damn thing every which way but still hits my hood..startin to gouge the ******
Old 02-01-2008, 11:24 AM
whatsgrip?'s Avatar
fire bird =
Camaro =
Corvette Z06 = sorry just to do it
Quick Reply: Trans Am Owners - Past or Present
