Sponsored by: DashLynx
RK SPort front air dam but no lip spoiler
Old 07-10-2003, 04:52 AM
2000SSNB's Avatar
Default RK SPort front air dam but no lip spoiler
Just installed a front air dam from RK sport but did no order the lip spoiler (goes underneath it to direct more air to the
radiators). What does GM use as lip spoiler on cars with
the ground effects package? Is it a different lip spoiler
from the one used on cars without the grounds effect package?
Gert
Old 07-10-2003, 08:25 PM
2000SSNB's Avatar
Default Re: RK SPort front air dam but no lip spoiler
anybody?
Old 07-10-2003, 08:53 PM
CrewRacerSS's Avatar
Hey I got the RKSport Ground Effects and I got the larger air dam. I wasn't going to put it on at first yet I did not want my car to over heat or not get enough air, so i put it on. GM uses the same air dam on all the camaros, with or without the GFX, because theirs do not block the center like the RKSport one does. So your safest bet is to put one on, it does scrap alot, but doesn't do any harm. Hope this helps.
Old 07-11-2003, 12:27 AM
onehardmaro's Avatar
I never put the air dam on and have no problems with over heating. If you do i suggest getting the fan mod which allows you to turn your fans on low or high when ever you want. High will bring my motor from 210 to 180 in about 2 minutes.
Quick Reply: RK SPort front air dam but no lip spoiler
