sts turbo tailpipe problem
after 3 months without a muffler or a tailpipe on my STS kit, i put one there today and i hate it because the truck wont make full boost and would only make it at higher RPMs. i didnt put a muffler, it is a 3 inch tailpipe that goes on the right corner. what are you guys with turbos using as a tailpipe or what would you recommend?
mods are:4.8 5 speed, Sts Turbo @7psi, Pacesetter Lts, 220/220 cam
That's weird. I have a Borla XR-1 after the turbo, and the car makes full boost by 3600-ish rpms (and that's a T76). Granted I'm only boosting 5 psi right now. I didn't see much of a difference in spool time at all when I put it on. I'm sure this doesn't help much, but just wanted to let you know my experience.
the million dollar question, take the tailpipe back off, does it go back to normal?
it might be something else completely but a freak coinkydink that when you put the tailpipe on it cropped up.
It may all be in your head too. I did the same thing, with the car quieter it just doesn't sound as fast. I also felt like I had a lot more low end torque with the muffler after the turbo than without.
i have the stock exhaust pipe and i build boost fine. wrap your exhaust from your y-pipe all the way back to the turbo.. yoiu will cut down spool time (spool quicker)
this is before i wrapped it
1 Post
Good luck
