What is the Best Bearings to use??
I did a search and found nothing. This would be for a 421 stroker 1100hp turbocharged. What bearings (crank, rods, cam) are the most optimal??
Do them make roller bearings for the cams? Any info on bearings would be great. Thanks.
we use clevite bearings for everything,most everything over 1000hp we get them coated with an antifriction coating,you can get roller cam bearings but they are pretty costly to install-not needed unless you are trying to get every last hp out of an engine.
