Another PCV Hose Question.
So I did my LS6 intake install this past weekend. After pulling my intake off, my rear driver side valve cover PCV hose snapped as it made the sharp angle as well as broke at the 2 to 1 connection.
My question now is that I ended up running a hose from the driver side port that sticks out of the valve cover (98) down to the PCV valve and back up to the other hoses at the throttle body. The only part left was the connection on the passenger side valve cover which I just capped off, is what I did okay for my car? I just read so many PCV questions but they all seem to involve getting a catch can.
Basically: does capping one point of the PCV system effect anything? Thanks
That is a bit confusing. I do not have a breather filter. Basically just bypassed the connection on the passenger valve cover. Unless I can find a T fitting then im not sure how I can re-connect it to the others.
