Is this a rod knock? Video
that definately sounds like rod nock... the "clunking" at least that I heard slightly in the begginning of the video...
the tapping noise sounds more like a valve or something hitting the pistons...
I recentley just spun a bearing and had some rod knock coming from the center. It sounded JUST like that... cept i didn't have the tapping noise that you have... So i'm thinking you have a couple problems... not just the one...
once we pulled my engine, we found out not only did i have a spun bearing, but all my valves hit all my pistons as well... which i would think would make that noise we are hearing in your video...
keep us updated
P.S. my engine eventually started shaking really bad after a few dyno runs as well... like once it got heated up real well from some abuse... but contrary to what 5.3Jimmy said, I didn't have any shavings in my oil at all...
keep us updated
This isn't my car, we just took the video of it while it was still on the trailer. I also think it's a rod. It sounds really deep down in the engine. I guess the owner thought it was a pushrod so he put new pushrods in. I told him that I think we need to pull the K member and drop the pan so I'll see what he wants to do..
