lq9 block, missing hole for j bracket mount
Old 02-02-2008, 09:39 PM
lmt0705's Avatar
Default lq9 block, missing hole for j bracket mount
is this a major issue? im running the sdce tensioner with the oil pan brace but im not real keen on the idea of missing a mounting bolt on that bracket, I looked into drilling and tapping but it looks like Ill be tapping right into #1 cylinder.
Old 02-02-2008, 11:08 PM
TT-TECH Veteran
Inspector12's Avatar
Most have drilled and tapped there should be a boss there for you to drill and tap.
Old 02-02-2008, 11:35 PM
NA$TY-TA's Avatar
Yep that's exactly what I did when I had the SDCE setup.
Search on here for the size Tap..... I think I posted the size. Its been 3 or 4 years now.
Kyle
Old 02-03-2008, 03:04 PM
lmt0705's Avatar
are the new style lq9 blocks different? mine has all long style head bolts, there is no boss there, it looks like id be drilling right into the #1 cylinder
Old 02-03-2008, 03:36 PM
NA$TY-TA's Avatar
Take a pic of it and post it up..............
Old 02-04-2008, 03:38 AM
lmt0705's Avatar
its already in the car with the blower on, so im going to try it, if I can get a pic of it I will
