Underdrive Pulley Question
Old 02-03-2008, 10:00 AM
alamantia's Avatar
Default Underdrive Pulley Question
In researching a cam for my car it was mentioned to me that since the crank pulley must be removed its a good idea to purchase an underdrive pulley. Has any experianced and charging or cooling issues using an underdrive pulley in their LSX vehical? I would imagine on a hot day in traffic there may be some overheating issues. Has anyone had any problems with this or are LSX vehicals void of thses issues?
Old 02-03-2008, 10:08 AM
dutinsss's Avatar
i dont have one, but i'm getting one soon probably. i've always heard that unless you have a decent sized sound system or something that would drain a good bit of electricity, your shouldn't have a problem.
Old 02-03-2008, 10:17 AM
87gnx's Avatar
I haven't had any prob's w/overheating or charging myself.I used a bit of "water wetter" and run around 190 in Aug. heat.
F.W.I.W. buy a new crank bolt when ya' put on the balancer.
Old 02-03-2008, 10:19 AM
Jon2kZ's Avatar
I have a pulley and yeah my charging goes negative at a stop light, but my warm in gear idle is at like 450rpm. If I ease it up by foot to 600 rpm it goes positive, so I need to get that adjusted.
If you're getting a cam you'll likely be getting a tune also and your idle we be set high enough that charging at idle will not be a problem.
Old 02-03-2008, 10:30 AM
alamantia's Avatar
good 2 know, thanx
Old 02-03-2008, 11:39 AM
redt/a2000's Avatar
with a cam your suppose to drill the hole in your throttle body a little until you correct your idle
Old 02-03-2008, 12:02 PM
Black99CamaroSS's Avatar
The same can be acheived with tuning and not molesting your TB.
Old 02-03-2008, 12:59 PM
Coy
Coy's Avatar
As stated above, no, you're not "suppose" to.
Old 02-03-2008, 04:11 PM
Moderator
davered00ss's Avatar
Ditto on the drill hole.
I have the SLP pully and no issues with charging or cooling.
Old 02-04-2008, 05:11 AM
Internet Mechanic
BlackScreaminMachine's Avatar
No issues what so ever, no tricks done, no lower deg thermos. Slap it on and forget it.
