Electric Vacuum Pump from SSBC
Could this unit by itself or being Overspun by BAP or other voltage multiplier pull enough vacuum through a Filtered Catch Can System to keep our intakes cleaner & in addition help to seal piston rings??? I would rather not install belt driven unit but like the benefits of a vacuum pump ...Just an idea, "Flame Suit On"
http://www.ssbrakes.com/pdf/AC001.pdf
I have this kit, I ran it on my Very Heavily Modified Tahoe (high 12's). It was a fully built engine with a supercharger. I have this entire kit sitting in a box, I only used it for a month and then I demodded the truck and put it back to stock. I didnt do any tests with it installed. It has great suction but I dont know if it can pull the volume. It would be interesting if someone installed it and did some testing.
LS1TECH Sponsor
I am using a vacuum pump from the old Caddy 4/6/8 motors. I was lucky enough to find one that was new. I as using a catch can in line as well. It seems to work fine.
1995 Pontiac Firebird Formula
388 LT1 stroker
Procharger F1 (22 psi)
FAST engine management
771 rwhp
682 rwtq
388 LT1 stroker
771 rwhp
682 rwtq
