Where can i get Bolts for transmission to engine?
Old 02-04-2008, 07:52 AM
Shawn MacAnanny's Avatar
Default Where can i get Bolts for transmission to engine?
I just got my T56 and my LS1 is just about back together, but I dont have any bolts to bolt the flywheel on (have bolts for the pressure plate) and i dont have any bolts to bolt the actually transmission to the engine block. Where can i get them, or atleast what size and grade are they? I know i can get ARP bolts for like $30 for the flywheel but what about the bellhousing to engine bolts?
Old 02-04-2008, 07:54 AM
00'blkss's Avatar
try the dealer they have or can get them or tell you what size
Old 02-04-2008, 08:26 AM
Internet Mechanic
BlackScreaminMachine's Avatar
The stealership can be pretty exp, I would just do ARP, its cheap ins.
Old 02-04-2008, 08:27 AM
PewterScreaminMach's Avatar
Yeah, I would just go to a dealer and ask. They overcharge like crazy for most stuff, but bolts and similar items are usually no big deal, especially since you know you're probably getting the right part from the dealer. A few extra dollars for piece of mind isn't a bad thing.
Old 02-04-2008, 04:07 PM
I'll try the dealer. I had to buy a bolt for my caliper on my truck one time somehow it fell out and it was only a couple $
Old 02-04-2008, 04:55 PM
jmm98LS1's Avatar
The bolts you need for attaching the trans to bellhousing and bellhousing to block are M10x1.5x40mm. They can be had at local hardware stores, just be sure to get high grade bolts.
