centerforce steel flywheel what the most i can turn down
im having a vibration issue im i am begining to think its either the clutch assmbly is outta balance or maybe drive shaft . but my question is about resurfacing the centerforce flywheel how much can be taken off to smooth it out or should i toss it an get another ?
You are wanting to resurface it to smooth out the vibration ? If you are removing the same amount of weight on the flywheel all the way around , the balance is going to remain the same . As far as the vibration , its pretty easy to eliminate the driveshaft . Does it do it sitting still in neutral ? If so its not the DS . If not then you have a pretty good chance that it is the DS . Most of the time an engine related vibration will get worse the higher the RPMs go . Most of the time a drivetrain issue will get worse the faster the vehicle goes .
PM me if you need to talk more about it .........
