shreveport/bossier hang out!
#681
Tough Mudder
How much do the Eibach springs lower the car? Buying lowering springs is the first/cheapest step in the process.
You then have to buy the matching shocks/struts or your car will ride like ****. If traction is something you like; you'll want relocation brackets for your lower control arms, then you'll decide you want better lower control arms because relocating stock ones is stupid. Then you'll want to center your rear, so you'll need an adjustable panhard bar. All because you want your car ~1" lower. Oh, I hope your exhaust doesn't hang low and that you don't ever want to drive comfortably over speed bumps.
I lowered mine, so I obviously like the idea. I just don't want you to think that this is something that can be done for $140.
#684
hey so ive got to get a tune whos the best around here? i heard theres an ol' boy out in the longview area that does a dyno tuneor hp tuners or something, or do yall have a hp tuner?
car is running sorta shitty after i took that egr stuff off!
#691
hilton after i get this vigilante you better call him for me. i will order the bung at the same time bc i know he is gonna need it. summit one ok?????
#692
Tough Mudder
Oh, and changing to 17's will have no effect on the gap. The aspect ratio of the tire will remain the same unless you go to a 28" tire; which is actually a pretty good option on a 15" wheel depending on your mods.
#696
Tough Mudder
I'd like a sig too. I want a picture of me nude, standing on my hood, like the statue of David. There should be a torch in my left hand and a sword in my right. I want a dragon lying in front of the car with a topless girl wearing an eye patch sitting on top of it. Terrified villagers should be running around... some on fire... you know, regular stuff.
Thanks in advance!
Thanks in advance!
#699
i want a new sig pic too....sorta like hiltons but different. ok mine is like this.....12 midgets, two yellow balloons, and one can of italian soup on a table with 6 plates 2 glasses no napkins all forks and a christmas tree in the center for decoration.
