shreveport/bossier hang out!
#1063
Tough Mudder
I'm BACK ONLINE!!! I'm thinking of writing a song about how much I hate comcast. It's craptastic!
All the interior is out of the Camaro right now. Apparently, my T-tops or something else leaks like a sieve. I had over an inch of standing water on the back seat floorboard. Pulled out all the seats, removed the carpet, cleaned up the whole mess.
#1067
hey shereport guys, we trying to put up a dyno day at thunder racing in baton rouge...seeing if any of you guys be willing to drive down for it....we got a post going lsx meet...so post up..................
#1069
Tough Mudder
Good news though. I found some tires. 275/50/15 et Streets.
engine? Should be strong enough
transmission? check
clutch? check
wheels/tires? Check
drive shaft/rear end? Uh... this is going to get expensive p.d.q.
I'll check out the Dyno thread.
#1070
Whenever you get ready!! It's all in good fun to me. The other reason I'm ordering all of this stuff is because we're about to get my wife a camaro also and I got alot of work ahead of me on that one so I'm trying to get mine somewhat finished, before I tackle her's. Oh yeah, and to beat AUTO's
#1075
i know what you're trying to do......demolish me at the track. make me look silly.......well i aint going back to the track so we are gonna have to settle this on the streets, like real men. im sure there is a guardrail i can push you towards.....
#1079
Don't believe everything you read about big cams being better. My best ET pass 11.29 and my best mph pass 124 both were run with my little TR224 cam. I swapped over to a much bigger TSP cam and can't match either of my best. I've run the bigger cam at lower DA and still couldn't match. I've blasted a ton of big cam cars with my 224 cam!
You just give up too much low end with those giant cams. I will be putting my TR224 cam back in after running my current setup with the new braked th350. Just talk to Todd and Jet from Monroe and Scott from Texark. about those big boy cams. You will only gain from a bigger cam if you are willing to wind your motor up past 68-6900rpm and if you do that with a stock short block you will turn it into a big pile of junk
#1080
