What causes HIGH idle in gear?!!?!
Old 02-05-2008, 12:31 AM
1fastz's Avatar
Default What causes HIGH idle in gear?!!?!
My car has been acting wierd as of late. The car seems perfectly okay in idle and once i put it in gear, it goes up to about 2,000rpms and stays there. While cruising, i dont even have to give it gas, becuase it stays at around 2,000rpms and actually pushes my car as though i would have the peddle down slightly. I didnt even touch the gas peddle and slowly it would go from 10mph to 15mph to 20mph and keep on going. When i come to a complete stop, I have to hold the brake down hard becuase it feels like it wants to still go. If i hold the brake long enough, it hesitates and slowly goes back down to a good idle, but if i let go of the brake, it goes back to what it was originally doing. What the hell would cause this!??!! and no codes are being thrown either
Old 02-05-2008, 05:05 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Its the tune, it needs to be adjusted. ODBII PCM's like to **** with settings after so many miles of driving, its common.
Old 02-05-2008, 05:09 AM
Race your car!
JL ws-6's Avatar
The iac valve could be sticking too, which would do this.
