Which oil pump?
Old 02-05-2008, 01:42 PM
ssduane's Avatar
Default Which oil pump?
I've done the search, found info on stock LS1, LS2 and LS6 pumps, ported, Melling HV, and HP pumps. My question is which pumps do not require any modification to the pump, timing cover etc..... In other words, which one is a direct bolt in. I have no issues using stock volume and pressure pumps, but still haven't deadset figure which ones will go straight on.
Old 02-05-2008, 02:09 PM
stevied916's Avatar
they all bolt in, its double roller chains that require modification. there is a thread about pumps 2 lines above yours...read that
Old 02-05-2008, 02:13 PM
DANOZ28's Avatar
i havent bought one but if i change motors i would look at SLP blueprinted oil pump. just my 2 cents.
Old 02-05-2008, 04:00 PM
kwiksilverz28's Avatar
Melling 296. Install as delivered. Stock fit.
Old 02-05-2008, 04:24 PM
JPH
JPH's Avatar
Melling #10296 pump and use BLUE spring! Best pump so far, for an the LS family of engines.
Old 02-05-2008, 04:41 PM
Leave the high pressure spring in.
