is this the right rear end for my car?
Banging some gears
http://store.summitracing.com/egnsea...115+4294901310
ive got a 2002 camaro ss 6speed... stocker finally took a fall the other day.. it was a torsen rear if this helps. i just dont want to order the wrong part.
Thanks in advance to whoever can answer this question for me
I would go with 31 spline axels, try TSP... They may be able to help you...
https://texas-speed.com/shop/categor...?MID=1&catid=6
Yes it is the correct part number but a bit pricey if you ask me. Check out our website for great deals on positractions and lockers. We have them in stock and ready to ship. We also have the carrier bearings and shims you will need to install the differential. Let me know if you have any questions.
Jeff
Jeff
Man if you are going to spend that much on the piece of **** 10 bolt you might as well save for a 9". You will be almost half way there after install, materials, and parts. Rule of thumb when it comes to a 10 bolt, Replace don't rebuild.
