H/C swap Checklist! Please read.
Restricted User
So I've decided to get a H/C package from TSP. Looks like it's going to be the AFR 205cc heads. Not sure exactly which cam I'm going to go with right now but it'll probably be either the 228R or T.v2. I just wanted to make sure I didn't miss anything when ordering my parts. This will be going on my 2002 SS w/ low mileage and full bolt ons. The package comes with hardened PRs and the heads are already assembled w/ springs. I believe I can use the stock rockers w/ these heads but not sure. I'm going to get a gasket set as well to include a GM head gasket. I'm also ordering a set of ARP head bolts. Is there anything else that I absolutely NEED?
Any and all input is greatly appreciated.
Restricted User
Okay, after talking with Matt from TSP, I've decided to go with a 224/228 .581/.588? on a 112+2 LSA. I may do a FAST 90/90 setup as well but I'm not sure. I'm confident that combo will give me plenty of really good power under the curve. This motor only has 25K miles and the lifters are in great shape. I've been debating doing an oil pump and timing chain because in my last car I saw absolutely NO difference in oil pressure. My current oil pressure is 40psi hot and looks great during drive cycles. I don't plan on swapping anything out in the future so I'm just going to go with the ARP head bolts. Should a low mileage 2002 SS need upgraded injectors for this setup?
I am at 97% duty cycle with stock heads. I would reccomend getting some GTP, yes GTP injectors- look for the cream colored ones as they are easy to tune, and cheap. they are 36# but flow like 39#'s on our fuel systems.
