Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
10 pt cage install...pics inside
Old 02-06-2008, 12:25 PM
Cam02ss's Avatar
Default 10 pt cage install...pics inside
Big thanks to Tyson @ PAF for doing a quality job as always on the 10 pt cage for the SS. I couldn't be happier with it. Here are a few pics-
Old 02-06-2008, 12:28 PM
Zger's Avatar
Looks nice. I was admiring your car when I dropped mine off a couple weeks ago.
Old 02-06-2008, 12:45 PM
NewCar's Avatar
Looks good. I only have an 8 pt
Old 02-06-2008, 12:52 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Nice.......
Old 02-06-2008, 01:00 PM
LS1LT1's Avatar
Thumbs up
Originally Posted by Cam02ss
That's a tough lookin' ride, black Camaros rule all.
Old 02-06-2008, 01:02 PM
8 second mod
Noyzee's Avatar
the removable bar is not ligit is it? thay will cirt that?
Old 02-06-2008, 01:17 PM
LS1Tech Sponsor
Slowhawk's Avatar
I was going to ask the same thing. I've read it is legit if you run a sill bar though-which I don't see.
Old 02-06-2008, 01:27 PM
8 second mod
Noyzee's Avatar
i think if you run a sill bar and have the correct thickness tube, and it wraps atleast 1/2 way bolted in with the correct holds, its ok, but that looks like a basic pull out bar that may not fly
Old 02-06-2008, 01:29 PM
TNTramair's Avatar
looks good Will!
Old 02-06-2008, 02:32 PM
Fireball's Avatar
Unless the rules changed for 2008, then a sillbar is not required on unibody cars with unmodified floorpans. Swingouts that have a 3/8 pin(or bolt) in double shear (which is what PAF uses) are legal to 8.50s.
Old 02-06-2008, 03:55 PM
Demonicbird00's Avatar
that looks really good!!
is it moly or mild?
-brandon
Old 02-06-2008, 04:38 PM
Frans96SS's Avatar
Looks good Will.... When you gonna let me work some magic on that thing
Old 02-06-2008, 06:45 PM
JRcamaroZ28's Avatar
looks good will!
and i agree i dont see anything stating that a rocker bar is req'd
Old 02-06-2008, 07:35 PM
bgblockelcamino's Avatar
looks good will
Old 02-06-2008, 07:56 PM
TheOutlaw1's Avatar
The removable door bars/swing-outs are good for 850's and is ligit. I have done several cages this way and their is no problem with getting them certified NHRA/IHRA. The rocker bars for sportsman cages are needed when their has been alterations done to OEM floor(example = Back half) Same goes for the Dash Bar.. only need for a modified firewall.. SFI cages...No swing-outs and dash and rocker bars are required..
Old 02-06-2008, 09:22 PM
mikep2002's Avatar
Big Question, Is the bottle in there now???
Old 02-07-2008, 07:10 AM
8 second mod
Noyzee's Avatar
good deal, looks good
Old 02-07-2008, 11:51 AM
ABA383's Avatar
Looks great Will...Even looks better in person...My 6 point turned out nice, too...Its at an interior shop getting new carpet today...
--Alan
Old 02-07-2008, 12:27 PM
bad2000z's Avatar
Nice freakin car.
Old 02-07-2008, 01:08 PM
BoostedLT5's Avatar
Is it legal to get a removable cross bar on a cage? I am going to need to have my GTO done soon and it would be a huge plus to be able to remove the bar and still have access to the rear seats as this is my everyday driver. I would only be running at the very best into the high 10's.
Thanks for any help guys. I cant see the pics because i am at work, but from what i have seen of tyson's work before i am sure it looks great!
