OEM 19x10 C6 Rims For FRONT...Check My Math Please
I've got four OEM 19x10 silver C6 rims (79mm offset) that I just mounted 275/30/19 Michelin Pilot Sport A/S tires on to run at all 4 corners. Pics can be seen here:
http://www.banddirector.cz28.com/photo2_1.html
I've already got 1.25" spacers for the rear, but I need a double check on my math to run the 19x10's on the front. It seems replica 19x10's that fit the F-Body use a 56mm offset. The OEM rims have a 79mm offset. 79mm - 56mm = 23mm. A 1" adapter is 25.4mm. Is it that simple or am I missing something? A 1" adapter is what I need to purchase, correct?
(It seems running the 1.25" adapter is common knowledge for the 79mm offset 19x10's on the rear, so that's what I bought for the rear.)
I just wanted to make sure before I order the 1" and then discover I actually needed the 1.25" for the front too.
TIA!
TIA!
I run 38 mm 9.5" on the front of my SS, so . . 79 mm - 31.75mm = 47.25 mm
It would move the wheel ~ 10 mm inwards compare to mine, and your wheel is 6.35 mm wider each side . .
Again, I am only guessing by my math calculations.
And FYI, no need to post in both theforum & the Stick I read virtually EVERY thread posted. . . .
I see you actually have the wheels. You may also want to mock it up.
Remove one wheel and tire. Set the lower A-Arm onto a block built to the regular ride height. Slide the 10" wheel on and see how far it can go on before the hoop gets too close to the spindle . . .
Just a thought.
Just a thought.
My problem is I'm lazy I guess I've already got a pair of 1.25" spacers and yes, I had the tires mounted and balanced earlier in the week. I guess I just need to go head to the garage and install the 2 spacers and the both rims/tires on one side of the car and see what happens.
The reason I was wanting to know about 1" spacers is that it seems to me that the stock rims/tires actually stick out further on the front than in the rear (not as bad as the early last generation of Mustangs mind you), so if I could bring them in 1/4" by just going with a 1" adapter, I thought that might be an option.
Do the front and rear tires run in the same track on 4th Gen F-Bodies, or are the rears brought in just a little from the fronts?
I also realize if I tried to go with the 1" adapters, I'd probably have to cut part of the unthreaded tip off of the front studs...not sure I want to do that...
Weather's nice today, so I went out and did a test fit. The 1.25" spacers are going to work well. It's VERY close in a couple of spots, so I'd be afraid the 1" spacers might make it too close. I'm going to order another set of 1.25" adapters and see how it all works out once I bolt everything down tight and go for a serious drive.
