flycutting for a tspv3??
My guess is it will fit. Would I run it with out checking? NFW... I put in a 243/248 on a 110 and PTV was almost nill... You have an M6, which means you need to be carefull...
I think its a cam from TSP... Here it is. Best advice is to conatct them via thru here or a phone call and ask them. I know they have ran that cam with all different combos.
http://www.texas-speed.com/shop/item...d=669&catid=44
plenty people rock that cam in stock headed ls1s should be no problems
their bigger ms4 cam fits fine as well
"Magic Stick V.4 239/242, .649"/.609" Camshaft With Your Choice of Lobe Seperation (111 LSA Standard)
The Magic Stick V4 camshaft is Texas Speed's premier LS1 camshaft!
The MS4 camshaft is the result of extensive engine dyno testing & research! Engine dyno results have shown over 80 horsepower gains with no other changes on a stock 2001 LS1 engine!! "
the torquer 3 is widely used
"All New Torquer v.3 Camshaft!
231/234 .643"/.598" 111 LSA
*Requires Aggressive Double Springs!
2300-6700 RPM Power Band with a peak around 6400rpm; This is an excellent performance camshaft with a rough idle! Custom tuning required"
And what makes you think LS1 heads are only good to .600 when LS6 heads are good for more? Can you post the flow sheet numbers you're referencing?
lol I knew when I saw the topic someone would make a post like this. I hope you aren't implying max lift has anything to do with PTV clearance. And I hope you aren't implying he's going to see .643 or w/e valve lift when you take hydraulic lifters and pushrod deflection into consideration.
Sorry man, i am new to this. But max lift has nothing to do with PTV clearance? Right? At all? PTV clearance has to do with the lsa?
Nope, at max lift the piston is down in the bore, it wouldn't make sense to have the valve at full lift with the piston coming back up would it? But it WOULD make sense that with the piston coming up to the top of the bore, the valve has not closed completely yet.. which is time off the seat.. which is duration.. and LSA and advance determining valve events.
I have this came and it rocks. I talked to TSP and they said it was fine on stock heads.
They also said it dynoed 7hp less than the MS4 during testing. Mine is on 111 lsa
hey ABQ99TA, i asked you a question in another post, i think it was the how big to go post or something, u didnt catch it. Anyway, i saw a member that was running the tspv2, and he was dynoing more than your setup, both bolt on cars, is this due to the tune? Or maybe the different years of cars(different heads)? Not trying to be rude or anything, just trying to understand why? Does the v2 typically put down more? I thought the v3 was a bigger cam
