cam with stock stall?
it will be annoying to be have stock stall and leave car in D at stop light. best to put it in neutral. once you have cam in. you will know what im talkin bout
i drive my ms3 with stock stall. but ima go 6 speed soon. so yea it can be dont. but the car wont perform like you want it to.
LS1TECH & Trucks Sponsor
As long as they dont' up your idle too much you can pull it off. You shouldn't, but you can
I drove a 232/234 stock stalled for a while
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
With a stock stall they likely won't raise it that high. It will probably be fairly low. It'll be more choppy thanks to the low idle and sound like more cam that it really is.
__________________
i would not reccommend a stock stall on a cam that size but yes it can be done. by doing that though you are not going to get the full power out of your cam by a long shot. i would highly reccommend that you get a stall asap b/c the car will not only drive nicer but it will be more fun. with a stall (when you get to it) i would reccommend a yank ss 3800 (i have the 3600 b/c i was scared to go bigger but now i wish i would have gone atleast a 3800 if not 4000 or 4200) good luck!
