New LS1 Owners - Newbie Tech - Loosing hot air while driving any ideas
texas12
02-07-2008, 04:26 PM
Ok so I took at a guess on this awhile back but im trying to mkae sure from some other people before i just take her to the shop for no reason. I have a 2002 Trans Am and right now im in alaska. Im stationed at Fort Wainwright and it gets cold as balls here. So I need my heater but the thing is my car will only hold the heat as it sits while driving the temp drops really bad and im not sure if its just a fan problem or what. My guess is because im driving in negative degree weather and that it sucks all the cold air in and thats the reason but im just trying to make sure before i go off and try and pay for her to get fixed and thats really it. If any one can help that would be awsome
chavez885
02-07-2008, 04:51 PM
Heater core is probably going out, might wanna replace it or blow it out. How many miles on the car? At idle is the air HOT or just warm.
Also try not to make multiple threads, try to list all your issues in one thread. :usa:
frisco88
02-07-2008, 06:20 PM
you might want to try replacing your thermostat 1st if its stck open your engine wont heat up especially while driving in cold climates,changing your heater core pit!
So-GT0071
02-07-2008, 08:12 PM
That is kinda what I was thinking..
BOONE
02-08-2008, 05:22 AM
I agree on this too, its easy (at least it would be inside a building). This would also be true if you have replaced it with a 160 degree for performance. They aren't going to heat like the stock temp thermostat will especially where you are.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
