auto head lights bypass
i want to do this but i saw that you can get to it by removing the radio? any one have a better how to? or a step by step write up? i dont want to go under the dash pad
Copy & Paste Moderator
If I remember correctly, DRL isn't the only thing that fails to function if you mess with the box behind the radio. The best way it to crimp together the two wires going to the light sensor. The system will think its always daytime and not turn on the head lights... check out the sticky.... there is a detailed pic.
Location: Your girl's back door giving her the long stroke while you're at work
I done mine on my old Z28 the way VIP1 posted. It disables the auto headlights but the parking lights will still be on during the day. You will then have full control of your headlights
It took me all of 5 minutes
And your brake light will be on all day long on your dashboard.
If I'm remembering right, just unplugging part of that box on my 2000 made my turn signals not work. I decided to do the solder 2 pins together mod...I didn't want DRL's or auto headlights though. I had them in my truck and it drove me nuts...but GM allows you to disable it in a silverado (just hit the dome override button 4 times fast or something)...don't have that option on the Camaro.
well because on my 9" my abs and brake light are on all the time.
now i remember reading a while ago jumping a wire in the abs fuse block made the abs and brake light go out. and the brake light worked like it should, this was onlu for 98 it said but no one could confirm it
