Wtb 93-02 Z28!!!!!!!!!!!!!
I am looking for a 93-02 camaro z28 6 spd ttops for under 8k no junk clean cars please i know yall have them I am in nashville TN if your close Ill come look or if your a ways away i can meet you
2000 A4 Z28 for $8500. PM me if interested. Here's a link to the thread:
https://ls1tech.com/forums/vehicles-sale-lsx-powered-only/867798-00-z28-8500-o-b-o.html
I have a 1997 Z28 Camaro 383 M6. Here is a break down of all that is done to it. I am asking $9,500.00 O.B.O. The Engine has 5,000 miles on it, and the Tranny has about 25,000miles on it. The car drives great but is not the best on gas. At idle with the tubular K-Member there is a lof of vibration but as you are driving it is smooth. if you have any questions pm me or call 806-584-1362 John.
ENGINE
*383 c.i. LT1 Balanced and Blueprinted
*BMR K-Member
*LE2 Heads Redone By G&G Performance engines to Stage 4 porting/5 angle valve job(flow 278/193)
12:1 Compression
Lloyd Elliott Ported LT1 Intake Painted Red
AFR Hydra-Rev Kit
*LE4 Custom Cam
*Melling HV Oil Pump
*+.030 Speed-Pro Forged Pistons
*3.75 Eagle Forged 4340 Crank
*Eagle Forged 5.7" H-beam Rods
*Total Seal gapless rings
*Clevite 77 bearings
*All ARP bolts and studs
*Canton Stroker 7qt Pan
1.6 Comp Promagnum Roller Rocker's
Comp chromoly pushrods
*Crane Performance Hydraulic Lifters
Comp 977 valvesprings w/ titanium retainers and locks
Moziere EWP
*GM Performance Parts LT4 Extreme Roller Timing Chain
*GM Performance Parts Opti Spark
*Professional Products SFI Certified Balancer
AS&M 58 mm Throttle Body
*AC Delete Pulley(comes with AC lines and Condenser though)
SLP CAI
*Bullitt High Torque Starter
*Custom Tall Polished valve covers
*Block Painted Black
*Brand new Alternator/ and Super Start Battery
No Cruise Control
SUSPENSION
SLP Double Diamond Subframe Connectors
BMR LCA's
LG Strut Bar
LG Double Adjustable PH Bar
QA1 R series struts w/ coil overs up front
QA1 12 way adjustable rears w/ stock springs
Rear Drag Airbags
TRANSMISSION
Stage 4 Jennings Engineering T56
B&M Ripper w/ WS6Store Shortshifter
*RAM HDX
*Resurfaced Flywheel
EXHAUST
Pacesetter Longtube's
Custom 3.5 inch Y-pipe with welded on "skid" plate for speed bumps
Custom 3.5 inch back exhaust to SLP 2OTL
DMH 3.5 inch Electric cut out
IGNITION/COMPUTER
MADZ28 Custom Tune
OBD1 Conversion
* TRE 255lph Race Pump w/ racetronix wiring harness
*Aeromotive Adjustable FPR
MSD Digital 6 w/ MSD coil
*NGK tr55's
Magnecore wires
INTERIOR
Wolfe 6 point Chromoly Rollbar weld in
Pair of Corbeau A4's - no back seat
Corbeau Driver and Passenger 4 Point Harnesses
Exterior
LT1 SS spoiler
ZR1's with Nitto 555r's on rear and 80% Nitto 555 on front
_________________
ENGINE
*BMR K-Member
12:1 Compression
AFR Hydra-Rev Kit
*LE4 Custom Cam
Moziere EWP
SLP CAI
No Cruise Control
SUSPENSION
BMR LCA's
LG Strut Bar
Rear Drag Airbags
TRANSMISSION
*RAM HDX
EXHAUST
IGNITION/COMPUTER
MADZ28 Custom Tune
OBD1 Conversion
*NGK tr55's
Magnecore wires
INTERIOR
Exterior
LT1 SS spoiler
_________________
