AFR Or Trick Flow Heads. Which is better?
As the title says, which head do you guys think will make more power? The AFR 205cc 61cc chamber or the Trick flow 215cc 61cc Chamber?.
They are both great heads with superior low/mid lift #'s but from what i am seeing TFS make a little more power. They also have a 13.5* valve angle which gives a little better PTV clearance. This allows you to mill a bit more to get better compression and run a bigger cam. On the down side you HAVE to run aftermarket rockers with TFS. I would with AFR too though because bronze guides and stock rockers are not the best to run together. I honestly can't see anybody disappointed with either one.
I have heard good reviews on both. But I would also take into account the customer service of AFR heads. I mean come on, Tony Mamo is always on this board - the guy who did major design work on the heads helps out individual customers with tech support all the time. His advice is always helpful and unbiased.
From the documentation Ive read TFS makes more power. The valve angles give superior piston to valve clearance.A gm purist will use this to their advantage and run a "he-man" cam...who knows mill that biatch a lil bit. Like Sombitch said...You have 2 run aftermarket rockers etc......For simplicity go afr...If you want to "go for broke" get the tfs.....
I agree with you. TFS have to run after market rocker arms so that is one reason they make a tad more power over the AFR heads using stock rockers. Both are great heads but I would (and did) run the AFRs. Get some Yella Terra rockers and you'll be right with the TFS head.
Between those two my choice went somewhere else: ETP 215...
Why???
Because I took a look at the technical aspect and the best of both brands is on the ETP Heads.
- Valve angle is rolled to 11° on the ETP vs.13.5° on the TFS and 15° for the AFR.
The ETP is the only one who made a casting with the same characteristics than the C5R, GM can't be wrong with the 24 hours Le Mans winning C5, don't you think?
- On the ETP heads the valve-train geometry is PERFECT with the OEM rockers and valve the train deflection is non-existant...
I rev my engine to 7450RPM with zero valve float.
- The ETP deck is the thickest when you compare the two others vs. the ETP...
- The ETP heads are the only one to have INSERTS from the factory to "on the top of the thick deck" improve rigidity, very well engineered sirs!!!
- ETP Factory or any of their dealers can deliver you from the factory the exact volume chamber you or your engine builder wants...for the same price!!!
- On the ETP heads the Intake port volume starts at 215cc then 225cc then 235cc then 245cc...thanks for the choice.
- The price is similar to the AFR and less than TSF when you add to those the roller rockers.
- At the end those ETP 215 in my daily driver stock cube stock shortblock on pump gaz that is so drivable than my wife use it...is producing 511rwhp and 455rwtq... and cruise 1200rpm in six gear or 20mph in a school zone in third...enough say I guess.
Regarding racing, in the big dog world, ETP is used by the best, but if you are racing, you know that you never tell the others what makes you the fastest...no???
The only problem is that ETP is selling so much that they don't need to advertise and you may wait a little more to obtain them vs.the competition.
Ready to be flamed!!!!!
Christian
Why???
Christian
Why???
Christian
Why???
Christian
