Drag Racing Tech - 385rwhp 381rwtq 98 WS6, what range should I be in at the track?
nighthawk355x
02-08-2008, 09:21 PM
My car's a 98 M6 WS6, stock weight except for no a/c compressor at the moment, put down 385rwhp and 381rwtq, anyone have a guess as to where my times and trap speeds should be?
I know it's hard to judge with a stick, but I'm just looking for an idea. I want to be able to gauge how good or bad I'm driving it when I go.
I'm a damn decent driver in general but have never launched a stick at the track. I know how to but I've never physically done it. My 60' in an A4 has always been high 1.9/2.0 or under with street tires and a pretty much stock car(cat-back, K+N, 2:73 rear). This car has 11" wide drag radials so I think I can do the launch, but we'll see. I figure I'll start at a 3k launch and maybe step it to 3500 max...I don't want to break it. :D
Any ideas on what kind of time and trap speed I should be looking for would be appreciated! My guess would be around 12.3ish at like 114 or so...sound about right or no?
Pro Stock John
02-09-2008, 09:43 AM
113-115mph, ET could be all over the place but a 12.2 would be going in the right direction. My Formy was around that dyno number years ago and went 11.7 but it was auto.
RAGENZ28
02-09-2008, 07:06 PM
11's all day
BadV8S10
02-13-2008, 09:02 PM
I'm making about the same power and with stock gears had a best of 12.21 at 117 so far.
nighthawk355x
02-13-2008, 09:05 PM
Thanks for the info guys.
Where should I leave at with a stock T56 & 10 bolt?
I want to run respectable without destroying everything. The car has a TA girdle & stud kit on it but otherwise it's the stock 10 bolt with 3:42's @ 74k miles. Same mileage for the trans and it has a Ram powergrip clutch with the mathing master & slave cyl's. Also has 11" wide BFG drag radials on it if that helps.
BOLO
02-13-2008, 09:43 PM
With that power, 11's are attainable. If you can shift and most of all get the car to hook, I don't see any problem. Good luck.
